Shim removal tool
modulation
Shim removal tool
Post by modulation »
Anyone have a cheap source for the shim removal tools. The pliers you use to hold the cam, and the wedge you use to hold the side of the bucket down so you can swap the shim without having to remove the cam? I can't find it much cheaper then $46, and for that much I should probably just spend the time to remove the cam.
Most of my valve lash is down to 0.010-0.013 but only cylinder 3 exhaust it's 0.016 and I see high EGTs on that cylinder as well, wondering if they are going to be related.
