Hey all! I figured I should get on here and get to know this site. I'm currently on my second turbo KA car, the first was a bone stock s14 with a cx racing tubo kit and a rs empathy tune.
Currently I have a 1999 s15 spec R with a fully built KA that makes 530whp. Will be getting a retune later this year once I have the car back together but I'll attach a build list below.
- 2.4L KA24DE-T
- Powder coated Valve cover with -12AN vents
- Race Port and Polished head
- KELFORD 272/272 camshafts
- JWT Jim Wolfe technology Adjustable cam gears
- CROWER Dual Valve Springs+ Retainers
- Head and block bored out and heli-coiled for 11mm head studs
- COMETIC MLS head gasket
- Head and block decked, micro polished, hot tanked and crosshoned
- ARIAS 8.8 Forged Pistons
- CROWER Billet Chromoly I-beam rods
- ARP L19 head studs
- ARP L19 rod bolts
- CLEVITE Rod and Main bearings
- COMPETITION light weight flywheel
- ACT HD unsprung 6 pick clutch
- 300zx Z32 TWIN TURBO 5 speed transmission
- XCESSIVE VG to KA transmission adapter kit
- XCESSIVE VG shifter relocation adapter kit
- Nismo Short shifter with Solid bushing
- XCESSIVE Aluminum 1 piece Driveshaft
- J30 VLSD differential
- Chase Bays clutch line
- Chase Bays BBE with tucked brake lines
- Chase Bays thermoswitch for dual ISR fans
- DW350 in line fuel pump
-8AN VIBRANT stainless steel braided fuel feed with AN fittings(E85)
-6AN VIBRANT stainless steel braided fuel return with AN fittings(E85)
- AEROMOTIVE inline fuel filter 10 micron
- AEROMOTIVE adjustable fuel regulator 1:1 rising rate
- INJECTOR DYNAMICS ID1000 injectors
- AMS -8AN fuel rail
- AEM progressive 50/50 water methanol injection with 550cc nozzle jet
- PRECISION TURBO 6262 billet wheel, dual ball bearing, .82AR turbine with Vband outlet
- TIALSport MVS 38mm Vband Wastegate
- TIALSport 50mm blow off valve
- APEXi N1 dual SS exhaust
- SPEARCO intercooler
- Custom Stainless Steel Equal Length Top Mount T3 manifold
- Custom VIBRANT Stainless Steel T304 open dump pipe
- Custom VIBRANT Stainless Steel T304 3& down pipe with o2 bung
- Custom VIBRANT Aluminum Intercooler Piping
- Custom Hand Made Aluminum Intake manifold
- ACCUFAB 5.0L throttle body with TPS
- AEM Full Standalone EMS
- AEM IAT Sensor
- AEM 3.5bar MAP Sensor
- LS3 Individual Ignition Smart coils with custom coil bracket
- NISSAN HIGH OUTPUT Q45 alternator upgrade
- Tein coilovers
- 78 works V4 tail lights
- DMAX rear overs
- Vertex body kit
- Work t7r wheels 18x9.5(F) 18x10.5(R) both +12
- Work lug nuts
- OEM headlights polished and protected with XPEL paint protection film
- Rocket bunny wing
Hello from Saskatchewan
Re: Hello from Saskatchewan
Welcome to the forum. Did you have to bang your tunnel out at all with the Xcessive tranny kit? I've got a line on a 5-speed from an N/A Z32 but hesitant to pull the trigger.
Car looks gorgeous.
Car looks gorgeous.
It all fit really well there is no need for bashing anything, where the starter sits is a bit tight but it fits!
Thank you, it'll look much nicer once it's finished and painted lol.
Very nice. I've got a cxracing kit sitting in my bedroom waiting to get put on. How did yours treat you? Good times or...?
Well this is awesome. I imagine there is some butthurt over it.
Love the car and the build list! Do you have a full build thread or more pictures? Curious about the 12an valve cover vents
