GT2876R 17.5PSI 375hp/356tq
modulation
Post by modulation »
Played with timing and got 10hp and tq or so, but didn't get much more from increase it any further so I backed off.
I upped boost controller too, and even with 16.5psi vs 15.5psi I only got a few HP, so my belief is I'm maxing out the T2 manifold at this point, or I need to degree my cams.
93 octane, -22cc pistons, 1.0mm head gasket (about 8.7:1 compression.)
Running 17 degrees of timing around 4000 rpms, and then 18 degrees around 5400, and 19 over 6000.
Re: GT2876R 17.5PSI 375hp/356tq
Post by p00t »
Great numbers!
I'm guessing you are right about the exhaust side choking it off and not allowing you to use up all of the compressor available. You might only gain a few HP with boost increase but your torque peak should still climb.
Are you still rolling on stock wheels with that power?
modulation
I have 235/45 R17 on the rear. (DZ102s)
I had around 330 ft/lb of torque on old cam/engine setup and found it undriveable with the stock 15' so I upgraded then.
