new kat dyno z31 turbo 8psi
AndrewHuffman
Post by AndrewHuffman »
1996 130k about 150 psi compression with jwt cams
step down harness for obdI nistune
sti yellow tops
z31 t3 1985 or 1986 rebuilt
oe s14 maf
q45 pump oe regulator
ebay fmic, manifold, wastegate, bov, exhaust, intake
8psi
93 octane
233whp 223 tq
vid
http://youtu.be/FfeuPgx8k64
AndrewHuffman
no love?
no hate?
lurker
jholman05
Post by jholman05 »
What made ya go with the z31 turbo? I made 20ftlbs more torque and the same power with my SR20 T25 at 7psi
I guess now you have an easy route to use a 3071 or HX/HY35.
Looks like a smooth dyno plot.
AndrewHuffman
I didn't want to choke the motor. The power band holds all the to redline. Also wanted something I could find in the junkyard. Keep it cheap.
LPime001
Post by LPime001 »
That is an awesome powerband.
Must feel amazing on the streets.
jholman05
Did you make those number on a stock block and pump gas?
Turbonetics 50 Trim T3/T4 .63ar
JGS Log Mani & Downpipe
Turbonetics Wastegate
Greddy Type RS Blow Off
PLX Wideband
Prosport Boost and Oil Gauge
CalumRT
WRX STI Injectors
jholman05
Post by jholman05 »
Yes to both, it did taper up top but made good torque down low... felt like driving a V8 that got 30mpg. I kind of miss the simplicity of that setup.
viewtopic.php?t=38177&highlight=
AndrewHuffman
stock motor, 93 octane
neverlift
Post by neverlift »
:P
I can safely say another 10~20 ft lbs are easily accessible with removing some fuel and upping the timing some, but knowing the actual goal of this tune and known weak ring lands I opted for a large safety net. And almost nailed the power level pre dyno. I guessed 220.
very strong on the street.
Huffman
whore those event vids..
wtf no tuner credit :? nistune didnt tune it lol
jaysol92
Post by jaysol92 »
That is definately a simple build but man that dyno graph is clean and constant. Nice work! especially considering its not expensive to replace or maintain.
AndrewHuffman
I'm thinking about selling my jet cams and either going 248/248 or bc stage 1 or 2.
Thoughts?
AtomGrimus
Re: new kat dyno z31 turbo 8psi
Post by AtomGrimus »
im like 2 years late here lol, i got a t3 z31 turbo, i did research and it says on other forums that this turbo can only hold up to 6psi idk how true that is.
lets get sidewayz d00d
ICEMAN.KCMO
Post by ICEMAN.KCMO »
That T3 is good to around 250Hp. I had the same turbo on a Dodge Daytona back in the day. Same turbo. I would go with this turbo aver the T25 any day of the week. T25 chokes power on top end..
Steve.
AndrewHuffman
I think it kept making power to 14psi
ICEMAN.KCMO
It is a great looking dyno. Power looks very smooth. You still have the same turbo setup?
Steve.
Post by street_240sx »
Hmmm should be good for alot more that that. I made 234/315 with a t25 off a ca18
AndrewHuffman
I got a new set up not, the old one detonated a piston after 1.5 years... I overheated the motor hot lapping at the track.
New engine is built, pretty much the same everywhere else, excepts I went with a gt3076r.
I made 280/270 on a mustang dyno at 13-14 psi
How did you make less than 300 hp or trq with a built motor?!?! I have a stock motor with a gt3076 and made 240/250 on 12psi and my motor has low compression in the #3
AndrewHuffman
Because forged internals=lower compression ratio.
Low boost, over safe tune. Rich and retarded
