745hp/679tq @ 39psi
redlineracer21
745hp/679tq @ 39psi
Post by redlineracer21 »
Finally took my car to get dyno tuned. Very happy with the numbers, especially for a mustang dyno. All of the pulls were done in 3rd since 4th gear overloaded the dyno...
Heres a video my tuner put together for me.
http://youtu.be/DByltHOVt2w
Re: 745hp/679tq @ 39psi
Post by cleantune »
Nice numbers! What kind of fuel setup were you running with this?
hotbox240
Post by hotbox240 »
Very legit! What clutch are you running?
ka240de
Post by ka240de »
Nice powerband edit thats alot of torque even for your numbers
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
RosadoRacing
Post by RosadoRacing »
Wow the s366 is making some serious power for 30psi. Can't wait to tune mine, im on the cast wheel but I'm also looking to boost 30psi. any pics?? Congrats btw
RosadoRacing
I just noticed the dyno says 29.97. did you mistype or did u run 39psi if so 745 seems low compared to the 609 u made on 20psi.
Post by supakat »
That is a sleeper...
redlineracer21
Fuel setup is dual walboros, -10 feed -6 return. Precision 95lb/hr primaries and 165lb/hr secondaries and e85.
Clutch is a 350z specialty z clutch. 5 puck with d21 flywheel.
The dyno only went up to 30psi but aem was showing 39ish.
The reason the numbers are low was because we had to do 3rd gear pulls instead of 4th. We tried one pull at first in 4th and overloaded the dyno by mph. We did a back to back pull in 3rd and lost around 30hp just from switching gears. This was also on a mustang dyno that reads low compared to dyno jet which is what the 609hp was tested on.
RosadoRacing
So your easily making over 800whp. 39psi on a s366 is def 800+
ka240de
Post by ka240de »
I request a spedo video of 3rd and 4th :) . Pleaase
also if you can get a 4th gear pull somewhere with a bit of tweaking , i think you would have the first 700wtq ka. Better beat kedbmx to it he should do the same with his new 10.5:1 setup.
redlineracer21
Sorry i was wrong. This graph was a 4th gear pull and apparently he changed the mph limit for this one. The reason for low power is most likely due to the t3 backside is getting restricted. It really needs to be t4...
RosadoRacing
So your .70 t3?? Wow that's tiny. I have a t4 .88 but you have a great powerband n made enormous power for a .70
NateDogg
Post by NateDogg »
That's awesome.
Looking at the chart it seems like the HP peak is a little low in the RPM range.
Do you think that's a result of the T3 exhaust housing?
What cams are you running?
'91 S13
Built, balanced KA-T
RosadoRacing
The t3 def is restricting the power in the upper rpm range. It starts falling off at 6300 when it should keep climbing to 8k+. Still one of if not the best powerband I seen on the site. I shift at 7 n only made 630whp n ran 10.5 he should be deep in the 9s!!
redlineracer21
It peaks early due to the small housing. Builds boost quicker so hp comes on sooner. I run the bc 272s cams.
Thanks rosadoracing! My goal is to just see a 9.99 sec pass. If i can get further that would be awesome.
nelson240sx
Post by nelson240sx »
Nice numbers, looks like she'd be a blast to drive
