S256 AGP @21psi
rtm240sx
S256 AGP @21psi
Post by rtm240sx »
ONLY REAL MEN STAY KA
hotbox240
Re: S256 AGP @21psi
Post by hotbox240 »
Looks like fun. This on pump gas?
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
rtm240sx
Re: S256 AGP @21psi
Post by rtm240sx »
Yeah on 93
i_slide
Re: S256 AGP @21psi
Post by i_slide »
Nice numbers! What compression and is this a t4 flange unit?
-Stock cams?
tuzzio
Re: S256 AGP @21psi
Post by tuzzio »
Interesting for sure, what hotside?
Also, what are your other specs. I'm running the 256sx with the .63AR myself.
SIL8D
Re: S256 AGP @21psi
Post by SIL8D »
looking for a s366 t3 flange
rtm240sx
Re: S256 AGP @21psi
Post by rtm240sx »
Rear housing is .75A/R divided housing.
NateDogg
Re: S256 AGP @21psi
Post by NateDogg »
Why your peak HP RPM so low?
S14 cams?
'91 S13
Built, balanced KA-T
Re: S256 AGP @21psi
Post by adamky »
NateDogg wrote:Why your peak HP RPM so low?
S14 cams?
His build list says Crower 264's and JWT gears.
viewtopic.php?p=529135#p529135
Does it hold boost steady until redline, or does it drop off? I'm also curious if the cams have been timed and if so, what they are set to.
