hey guys,
im looking into getting a bushing kit for my car i looked on ebay and there kits come with
Bushings Included:
Front Control Arm Bushings
Rear Control Arm Bushings
Front Strut Rod Bushings
Front 27mm Sway Bar Bushings
Rear 16mm Sway Bar Bushings
Tie-Rod End Boots
i wanted to know is there any other bushings i will need i pretty much was to replace all my bushing so its like a new car. i know i need some diff bushings but i dont no what bush diff bushings to buy. i have a 300zx diff right now and i think im useing the stock s14 bushings for that cant remember been so long. but i am going to be installing a Q45 diff really soon so anyone know what bushings i need for that diff will bushings from a s14 work on there too cause im going to buy new bushings for that too just dont no witch ones i need anyone know any info on this please help. also let me know if there other bushings i need to replace or will this kit cover all the bushings needed.
i use my car for drag and streetracing mainly no drift at all so what u think i need thank you!
Bushing Kit
Re: Bushing Kit
anyone at all has an idea? im thinking the s14 one should work on my Q45 but just want to hear a confirm on this
Re: Bushing Kit
Yes s14 diff bushings will work.I'm using s14 energy bushings in my q45 rear. How are your rear subframe bushings.
Re: Bushing Kit
thank you for ur reply my bushing are not that bad but i want all new bushings so ill be buying the same ones u have just didnt no if the s14 would work. thanks
Re: Bushing Kit
That being said,are you willing to sacrifice some handling to get the most traction possible or are you wanting to keep handling priority and sacrifice some traction?
