Z32 trans
Re: Z32 trans
700.. 800.. 900... really depends on how you use/abuse it, but they are very stout transmissions.
Re: Z32 trans
What amount of torque does the ka24de transmission start having problems at?
Re: Z32 trans
The only one that comes to mind immediately is kedbmx. He destroyed the KA 3rd gear rolling into the throttle with good tires and lots of traction. He was around 500-550whp back then, IIRC.
This is a picture of a SR20DE vs a Z33 transmission, but the SR trans is the same as the KA, and the Z33 gears are similar in size to the Z32 gears. The difference in gear size alone is ridiculous.
Stock trans
Z32 trans
Stock trans
Z32 trans
Re: Z32 trans
Ok thanks for the reply.i launched my car on toyo r888s 1 time and bye bye trans.ill post pics when I pull it and get it apart lol
Re: Z32 trans
I broke the stock trans after a 11.6 pass at 14psi 440whp 350tq. it did last on The dyno when i made 660whp but the launch on slicks broke on the driveshaft side. I since been running the z32 no issues10.5 passes all day
- s14fiend
Re: Z32 trans
RosadoRacing wrote:I broke the stock trans after a 11.6 pass at 14psi 440whp 350tq. it did last on The dyno when i made 660whp but the launch on slicks broke on the driveshaft side. I since been running the z32 no issues10.5 passes all day
At what RPM and what differential gear?
Re: Z32 trans
I crossed the line around 7300rpm with the 4.08 gears. I now have 4.11 gears with a slightly taller tire a true 26" before i had a 25.8". Im hoping to hit 155mph at 8000rpm.
Re: Z32 trans
4th gear...
