OBD1 KA24DET TUNES HOSTED AND POSTED!
- BigLoukaT
8-bit, is there any chance that we can host Calumsult program downloads on the site now that calum isn't hosting them anymore? In an effort to avoid manually sending/ emailing the exes to people who need them
- MTX450
Which programs are you looking for?BigLoukaT wrote:8-bit, is there any chance that we can host Calumsult program downloads on the site now that calum isn't hosting them anymore? In an effort to avoid manually sending/ emailing the exes to people who need them
EFI Tuner
Haltech Engine Management Systems
- BigLoukaT
I'm not looking for them anymore, however I needed the tp beta exe recently since my original copy wasn't working, and couldn't dl it. Luckily a member here was nice enough to troubleshoot and send me a known working copy.MTX450 wrote:Which programs are you looking for?BigLoukaT wrote:8-bit, is there any chance that we can host Calumsult program downloads on the site now that calum isn't hosting them anymore? In an effort to avoid manually sending/ emailing the exes to people who need them
Not even two weeks after I posted up looking for Calumsult stuff, another kat member posted a need for the programs. I just think that it would be great to have them hosted, if willing, so you wouldn't have to rely on people to email them out.
if one of ya'll would e-mail them all to me I will host. I know a guy right now looking for the TP beta calumsult.
- BigLoukaT
8-bit - great news, thanks. I would be happy to email them to you, but I ran into a prob trying to email them to another member last night.... one file included in the Calumsult full installer is over 25 mb, and would not compress down below 25 while zipping, so gmail won't allow me to send as an attachment
Use the file upload service listed above and send me the link for your files
- BigLoukaT
CalumSult - Full Installer, plus LW2 Beta and TP Beta (zipped):
http://www.mediafire.com/?2zf06ly6o3b0319
CalumSult - LW2 Beta and TP Beta (zipped):
http://www.mediafire.com/?2yfy5gmxa634qwh
I separated them to cut down on unneccesary network traffic (no need to dl calumsult full since that's 30 mb if you only need tp beta or lw2 beta). I don't know how much of a hosting service you can provide for, but i figured it would help.
new link for my S14, 370cc, stockMAFS tune.
- emo_tactical9
I've got those files hosted also, in the link in my sig. I also have the drivers there for calumsult.
I just cleaned up the layout a little bit and put all the XDF files at the top with clear designations... I'm considering converting my s14 370cc tune to a LC tune... sounds fun.
if it matters at all, im steve and this tune was made by calum as a ball park get me started tune. after k and lat adj it was real rich (10.0) and real retarded (14* rising toward redline) WOT, exactly what he intended. i only tested it at 8psi, and just molded the bin to fit. im a bum ill send what i got, and just resend it once i retune for my faster spooling turbo in a few weeks.
0psi=43
8=63
13=76
16=83
did he ever give u feedback or get his map from his dyno session?
and regarding feedback from 740/n62 users and the map u made for pearl: personally i was atThis tune is a 'ballpark' tune submitted PEARL240SX who got it from a guy named "Steve" for the following setup:
72lb injectors (~740cc)
Z32 MAFS
N/A (but looks to have room up to what I estimate to be about 10psi of boost).
http://www.liquidmathematics.com/tunes/ ... Z32MAF.bin
0psi=43
8=63
13=76
16=83
This tune is a base setup tune from JWROSE for the following setup:
t3/t04e
550cc
z32 maf
S14 95 OBD1 ECU (please let me know if this assumption is wrong dude)
http://www.liquidmathematics.com/tunes/ ... %20MAF.bin
i know this is a base tune, but it looks extremely rich. im looking for a base tune to drive my car about 150 miles with this setup. i just dont want anything to happen.
t3/t04e
550cc
z32 maf
Re: OBD1 KA24DET TUNES HOSTED AND POSTED!
Can someone double check this for me.
Timing seems to be set up for boost but the TP scale is set up for a N/A application.
Am I right?
Jeff
the title says DET... i would think the tp to be a large number due to the maf/inj combo. im at work so i cant view it.body80 wrote:Can someone double check this for me.
Am I right?
Stock TP
Bin file TP and with Fuel and Spark maps
sonofa!! i cant see photo bucket pics at work either, lol. but good man none the less! off to my phone so i can see it.
EDIT
OK body80,
a stock bin runs past the map. about 107 TP WOT. the TP in the "tune" has def been scaled for new injectors and maf. the timing, depending on what TP WOT, is set for somewhere in the region of 7 - 13ish psi BUT i very much so DISLIKE how the timing jumps 4 degrees above 6400. thats cool if it was dyno tuned that way but id keep it the same all the way up. colum 46 may be for 7psi and colum 59 may be for 13ish psi. you can only assume with out knowing the tuner or easing into it yourself.
EDIT
OK body80,
baised on you K and injector latency 11 in the map may not = 11 on the WB. with tuning its a do what you gotta do to get it to do what you want it to do kinda deal. in my experience the K and Lat that have yeilded the desired results have not yeilded an exact match in theoretical fuel and actual. close but not exact, some tuines have been .5 off, some over 1.Andyv20sx wrote:This tune is a base setup tune from JWROSE for the following setup:
t3/t04e
550cc
z32 maf
TUNE THAT bi*ch and then u dont gotta worry.
any chance there is someone out there with some e85 tunes laying around? I know chipped ecu's are a bit different in the idle/cruise, but wanted to get some ideas for my megasquirt diypnp
open that bad boy up with a LC bin...ya see how under scalars theres a tab for timing retard amount? thats where u enter a single value for the amount u wish to retard. likewise there a tab for time and one for speed at which its disabled. tbh im not sure what "trigger point for timing retard" actually is. keep in mind u HAVE to copy over your maps to a LC enabled bin as there is "code" written into the bin to make it work.
nope its just a single set point. obviously, set it to 4k, mash pedal and u get 4k. its definitely a very basic thing. calum was calling it "simple launch control"
is there any way that someone can help me out, i just got my car running but like poo, and a friend completely ruined the tune i had, so if someone coyuld help it would be awesome
550cc injectors
t3t04e
lightning maf
93 obd1 s13 ecu
stock compression and fuel pressure
550cc injectors
t3t04e
lightning maf
93 obd1 s13 ecu
no replacement for displacement????
TRY BOOST!!!
TRY BOOST!!!
How does the fan control work?
I keep changing the temps to get the fans not to automatically turn on when I start the car, but it doesn't make a difference.
I'm going on the assumption that the temps represent when the fans come on, is that right? If so, why are they still on when I set them to 99*C?
huh. not to state the obvious, but you have to hit save bin, the fantemp program is not realtime. you also have to then re-upload the bin in tunerpro to get the changes.
im still not sure why the fantemp program is not in the original post. wink wink cody.
huh, whats weird is the factory set point is 205 iirc. i tested it and it worked, so im unsure (as u are) why their staying on. then i went and changed all values to 83c and...well it worked. i would try a fresh bin and make sure they dont go on till 205. if they go on earlier with the stock set points, you know somethings up. your wiring is all factory for that plug?
I have different fans, but I wired it straight to the one connector with just ground and power so I doubt it's that.
I'm assuming I just messed something up with Tunerpro because I was tinkering with it for a while trying to find my way around.
I'll play with it some more tomorrow and hopefully I can figure it out.
