Daigle’s S14
Re: Daigle’s S14 - Looking for Opinions on PS setup
Post by sdaigle240 »
yeah i look at headlight retrofits all the time lol. but thats like 300$ that could be spent on cooler stuffs. like MAX.. theyre front and rear knuckles at 400 each are just a retardedly stupid dumb deal. i dont even know how they make money, especially the rears with the spherical bearings. thinking i might make a few more sets of knuckles to sell and just buy PBM **** lol. the other half of me says "your setups already so much better than it was b4 just be happy and go buy a body kit" lol
so so good...
http://www.partsshopmax.com/page.php?39
Re: Daigle’s S14 - LCA's extended, notched, boxed and stoppe
LCA WErK
added 1/2", box'd n notched'd, adjustable stopper and added some meat to the knuckle to accommodate it.
Re: Daigle’s S14 - LCA's extended notched boxed adj stops
Post by supakat »
Nice work. I see you are really enjoying the car now more than before. Keep it up.
thanks supa! yeah i really like to tinker and fab, apparently almost as much as driving the thing! ...i am missing events though :( but hey motivation struck me and i went with it. Im skipping the tubs for now, between time and them not seeming completly necessary ill just save it for another project. i really want to drive but i also really want to stuff in a welded diff and mod my subframe bushies into risers. so another projects already lined up.
ka240de
Post by ka240de »
really cool fab work you've done here ! cant wait to see how the lca mods affect things
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
thank you kind sir! im going to hold off posting the picture untill its all bolted down but its got pretty serious angle. Im most excited about the reduction on turns lock to lock. from about 3.25 to 2.5 so that should translate to a lot less wheel input while sliding. thats why **** takes me so long. overthink overthink overthink execute and enjoy.
ka240de
Post by ka240de »
yeah it might also be something to get used to if you've drifted the car before! I can imagine that would make things easier for sure
sloooowly making progress. brake lines done, just gotta insulate with fuel line and adel clamps. also working on fuse box relocation. box is going half in the bay half in the fender well. all cut out and fit up, just extending a few wires and need to build a metal box off the chasis to keep the back side of the box out of the elements.
m10x1.0 to -3AN fittings with -3 tube nuts and tubes. using a ridgid 37* flare tool.
Re: Daigle’s S14 - Tucked Brake Lines w/Banjos 7/8/14
hard lined the WG setup
Fuse box relocation - tight everywhere but clears everything.
some light tint on the headlight.... do like.
moved the PS Res. also tight everywhere but fits mint
typical rot spot. all fixed up now.
redid the brake shield. lil more triming
Re: Daigle’s S14 - Fuse Box & PS Res Relocated, rot repair 7
Post by adamky »
The fuse box relocation is very innovative. Tucked out of the way but still accessible. Pimp. The PS relocation is great too. There's a lot of wasted space in that area and that's a good way to make use of it. I can't believe I've never seen anyone else do that before.
Don't be surprised when you see me copying some of your ideas! Keep up the good work.
Post by supakat »
Great work daigle! Finished product is gonna look clean. I still amazed on the fuse location. Sick.
Thanks my Doods! hey have at it, i throw my twist on things but of course get the motivation from other other smart bros. props to my bro toby (i think altimaDET) for showing me the fuse box location. i just live in new england and wanted to have it all sealed up. the PS idea i dunno but saw it somewhere. just grab a spare stock 10mm bolt, about 1.5-2" long and tack it to the flat sheet metal under that corner. i used a stock s13 res (obviously) and made use of half the stock bracket. i cut of the larger of the two tabs and made use of the rubber insulated bushing thing on the smaller tab. threw a washer on the bolt then put the reservoir and bam, tight tight, yet insulated. with out the washer it was pretty floppy.
Post by shift_down »
adamky wrote: Don't be surprised when you see me copying some of your ideas! Keep up the good work.
This!
I love the way you did this and other aspects of your build. Great job. This is inspirational. My fuse box is a huge mess with wires all over the place. Im going to do some work from the inspiration of yours. Keep it up, because I want to copy more stuff!
damn... im inspiring bros. thats whats up... all about that brotovation. thanks shift!
Post by airman »
Haha brotivation. I like it. It's 6AM here and now I'm going out to the shop to straighten up for when I get home from work this afternoon...for tonight...I (may) dine as a KA-ter!
I love seeing this kind of stuff in builds. Fuse box is ace. On the brake banjo bolts, did you use copper washers? If so, did you feel it necessary to true up/flatten/machine the "face" of each outlet, or do the threads seal it well enough?
airman wrote:Haha brotivation. I like it. It's 6AM here and now I'm going out to the shop to straighten up for when I get home from work this afternoon...for tonight...I (may) dine as a KA-ter!
ohhh sheeet! its time huh. my buddies and i have this turrible tendency of broing everything. from talking about a fitness brogram to discussing what were broing to be doing that night. haha its is most definitely out of control. thanks for the props. the washers on the banjo are aluminum. i just copied a buddies setup whose been running his like this for a few years. id be happy to post up part numbers if anyones interested. think i spent around 75 bucks to do the brake lines and fittings. had to borrow an AN/JIC flare tool though.
mattheripper
Post by mattheripper »
Yeah those relocations are ridiculously hidden! Excellent job! Are you keeping A/C? I wish I did, I have my ps down there now though.
Your running a Tial wastegate right? 38mm? Whats the lowest psi you can steadily hold with the holset on there?
I want to run 10-12 psi to make my stock engines last as long as possible. But the lowest I can set my ebay tial knockoff and mbc to is 15 psi no spiking so thats good, but its a 6-7 psi spring lol.
I have a ebc on the way and am considering synapse's 40mm wastgate that bolts in. But yeah how much is your 38mm tubing able to bleed out?
R32 KA24DET HE341 MEGASQUIRT DIYPNP S13 suspension 18x10/12
Click it >>>> viewtopic.php?t=56032
mattheripper wrote:Yeah those relocations are ridiculously hidden! Excellent job! Are you keeping A/C? I wish I did, I have my ps down there now though.
tahnks dood. i am indeed keeping AC. i feel like a 400hp caged track car with AC would be pretty cool. I want to keep it as daily friendly as possible...if thats possible with a cage lol.
yeah tial 38 with a 12# spring and it holds pretty good. i run it at 18 and its been a looong time since ive ran lower but i dont ever recall any creep. of course you always get a touch of spike, a psi or so. i did see your comment on that ebay WG..... LOL.
mattheripper
Haha I don't even remember what eBay wg comment your referring to what was it(haha never mind it see where I said something about it). But guess what?
I just took it out with buddy to smooth out the ve table. Took out the mbc and only fed the bottom port on the wastegate and it held 7psi all the way to 7500. I was so stoked. Almost thought l might have to redo my piping for bigger stuff and get a good wg right away AND have even more downtime before I could fully tune. But right now it's not creeping so hopefully the ebc will be all I need to up the boost safely. 15psi felt sick but I don't need it and I'm not built. Lol
mattheripper wrote:Haha I don't even remember what eBay wg comment your referring to what was it(haha never mind it see where I said something about it). But guess what?
yeah I meant that your 7# egay gate holds 14# lol, that **** is very funny to me. glad to hear you got it sorted. id say keep it to 12psi if your not looking to rebuild the motor for a while. that'll last with a solid tune.
same paint, different angles and lighting.
duplicolor gloss black caliper paint
metalcast anodized transparent purple (2 dustings)
gloss
wet sand
wax
**** is wild... constantly changes appearance. you may spot what appears to be imperfections in the purple application but its actually just lighting. a small dimple creates a very different look than the metal adjacent to it. i love that it pretty much looks black, untill further inspection.
between this and my truck bed liner idea years back im like the **** rattle can sensai
Re: Daigle’s S14 - Painted Bay 7/22
thats enough wet sanding for me. bahh that **** sucks. i see how you could just keep going but good enough for me. here she is kinda waxed.
PatPutter14
Post by PatPutter14 »
About to do this myself once swap starts
Theres no Replacement for Displacement! Machine it Right the First Time....
the mods turned out awesome. my car gained insane turn in grip. i think my drift car would do really well at autox with some meats on the back right now lol. definitely feels more agile than how ive autox'd it years ago. the faster steering ratio is awesome, i just cant get over the way it progressively gains grip the harder you turn in. it all makes sence, i added 2 more degrees of camber, which translated to more contact patch while turning (and less while driving straight lol) and i can feel it. the front end felt amazingly planted and really handled the added shear from additional angle without washing out or anything. my old poly rack bushings were hammered by the end of the second day so i got some PBM alu ones on the way. i was also pleased to see they DONT RUB! well they rub on the frame rail above the tire but i call those my "bump stops" lol. 17x10 +0 with a 1/2" extended LCA at 4.8* camber, ~8.5 caster.
unfortunately due to an error in my WG hardline execution i was stuck to 12 psi but still managed. also swithed back to recirc'd WG.. it had been a while, and i can shamelessly say my car sounds amazing. a kid rolled up in a kouki asked me what i had cuz it sounded amazing. i later realized he had an rb26 in his car... lol! awesome.
https://www.youtube.com/watch?v=Wi1Q4Aiv4qU
mattheripper
Re: Daigle’s S14 - ClubLooseNorth Event
Dude YES! 12psi looks just fine. I've been streeting on 7 haha and it's been okay. And your smoke I wanna be there. ***** looks good dude.
And hey do you have a way of measuring caster? Or do you have to somewhere?
thanks man! my caster methods are ghetto at best. my buddy has a kit but i cant seem to get a realistic caster measurement out of it (3*). i knew my caster was set to 7.8 years ago at a higher ride height (maybe 2" higher lol) so i figured it had to be atleast that. i was replacing the heims so i just added length right off the bat and adjusted till both coils read the same mean number. obviously you cant align the gauge dead straight so if you go back and forth you can get a pretty good feel for the average or center. i dont claim this to be accurate, but i do feel my caster is even and thats whats important to me. the wheel is in the center of the well anyway, much movement in either direction would cause rub. my wheel centers just fine while drifting, so wherever im at, i dont see a need for more. i like how our sport is about feel. its just whatever feels good to you, right now i am feeeelin this **** righ hea.
this is some of the more hood rat **** you'll ever catch me doing haha
Post by adamky »
I didn't see anything in the last few replies other than two girls in short shorts. I'll come back later and attempt to locate some pics of the car and any words that were included.
<-Perv https://www.youtube.com/watch?v=_m-7CrWkrFk
Kidding. I'd love to hear the exhaust. Got any videos of it?
mattheripper
Haha I'm down with that level of hoodrattery. Thanks for the info. Also :handgestures-thumbup: on the short shorts pic!
I'm amazed with how different our cars sound. I uploaded a 13 second clip of the other day's streeting and I'm gonna link it in my build right after this so you can see. Its nothing to brag about simply upload it to show the sound difference.
HoEs bE HyPnOtIzEd bY ThAt ChRoME
haha yeah im sayin, them bunz. Adam, did ya breeze right over the YT link? it was located vanishingly close to said bunz though so you might have. check it out: https://www.youtube.com/watch?v=Wi1Q4Aiv4qU
matt, post it up! i havent "heard" anything on your IG account. i think one of the biggest factors is the type of manifold. seems like long tubes sound the sweetest. ive got like a shorty tube mani.
matt heres one with the dump tube in instead of recirc'd. the video makes it sound a bit more tasteful than i think it actually is.
https://www.youtube.com/watch?v=8RWvUCCGxQ4
