Old 14yr 1st build > viewtopic.php?t=37638
My First build netted
~380whp 360tq >viewtopic.php?f=3&t=44599
Its always gotta be more 2nd time around right?
Its Been a Long time. About 14 years. A few months after finishing my build and enjoying the car the clutch slipped and wouldn't hold 18psi. I was going to get a 350z clutch in there, but I got stopped by a cop (CA) and they gave me a state ref. At that moment, I was done with racing, I was tired of the car stuff. So I sold EVERY MOD and put the car back to stock. Gave the car to my brother to Drive as a daily. Fast forward a few years he got another DD and I said okay i'm taking the 240sx back. Its been parked since. Never really had a urge to Mod it back but knew I would never sell it. Well....come 2019 and I Decided to build a track street car. I started ordering parts as I see. Well now Here we are . 2022
Like the past build, Machine shop did the machine work and I assembled it myself
What I can tell you is as time goes by, Your skills and ability will always carry you to be better. This is what it is so far. Still deciding on a few factors like ECU, Cams, ect
Goal Is mainly road racing/drag. and flex e85
Mainly going to be a picture thread to show what I have done. At this moment. Engine is built and running and in the break in phase. I choose to Break in NA.
Here are the Specs
Engine
KA24DE S13 Block
90mm JE 9:1 Forged Pistons @ .019 Top, .022 2nd Ring clearance
K1 forged rods
King Racing XP Main Bearings @0015-.002 In Clearance
King Racing XP Rod Bearings @.002 In Clearance
ARP 10mm Head studs
ARP head stud collar washers
ARP Main studs
Tomei 1.2 Head gasket
Full Rotating assembly Balanced
JGS Engine mounts
Greddy Oil cooler Adapter -to be installed after break in
Setrab oil cooler 13row- to be installed after break in
Turbo
Custom Top mount manifold Ceramic coated
BorgWarner 257sxe T3 housing
Tial 44mm Wastegate
Mishimoto R line intercooler
Turbosmart Racegate
MAC 3 port Boost solenoid
HKS sport 3" exhaust
Cooling
Mishimoto Radiator
3.8 Ford Taurus Fan
Water Wetter, 50/50 Oat Asian coolant
Fuel System
Walbro Hellcat Pump 525 F90000285
AMS Top Feed Fuel Rail
ID 1300x Injectors
Radium Injector Seats
Aeromotive FPR
Aeromotive Fuel Filter
Fuel pump Rewire/Relay 10 Guage
Drivetrain
Z32 Na Transmission
Z32 MAZworx Conversion Plate
ACT 350Z clutch kit
13lb RB25 Ebay Flywheel (Balanced with Pressure Plate)
Xcessive Short Z32 Shifter Bracket
Z1 Motorsports RHD Z32 Shifter
Megan trans mount
MT-90 Fluid
Gauges setup
Autometer Sport-comp II -Boost
Autometer Sport-comp II -Water temp
Autometer Sport-comp II -Oil pressure
Innovated ECB-1 Wideband/Ethanol/Boost Gauge
Electronics
Quest 125A Alternator with spherical rod end bracket
COP- Debating Maxima or K coils
ECU- Debating AEM V2,or ECUmaster or LINK (What I need is Flex, boost by gear)
AIT Sensor
3.5 bar MAP sensor
Suspension
Apex-I EXV coil-overs
SPL tension Rods
SPL Outer tie rods
Z32 Inner Tie rods
ST Front/Rear Sway bar kit
Ingalls Toe arm
Peak Performance Upper control arm
Full Lockout Bolt kit for rear end
Brakes
Still waiting for completion of car to throw on last
Jdm S14 Front calipers (Z32)
-still need >rear Z32 calipers and ebrake
https://lh3.googleusercontent.com/BXQHx ... authuser=0
Importdude's build 2.0- 14 year come back
Re: Importdude's build 2.0- 14 year come back
Pictures don't work, but i'm excited to see. Also, I'm a current AEM V2 owner, and if my AEM died today, I'd probably go with a LINK instead of replacing it with another V2
My buddy Bryant switched from a V2 to a Haltech and won't stop trying to sell me one.
looking forward to the pics.
Everything is runing But cannot get it to run with the DIY trigger wheel megasquirt pnp2
with the stock wheel it runs and idles.
Welcome back!
I don't think you can attach photos through google like that. Get those pictures to work we want to see!
It's crazy that your old car is still around. With my luck after being loaned out it was not coming back.
And I hear ya about being done with racing. I was pretty lucky many times way back then. It helps to have friends that help you out of a jam too!
- KA-T.org Sponsor
importdude wrote: ↑Wed Jul 13, 2022 3:00 pm Everything is runing But cannot get it to run with the DIY trigger wheel megasquirt pnp2
What model MSPNP Gen2? We have three for various KA24DE cars:
1989-1994 https://www.diyautotune.com/product/meg ... ual-trans/
1995 240sx (and 95-97 Sentra/200sx/Altima) https://www.diyautotune.com/product/meg ... ual-trans/
1996-1998 240sx https://www.diyautotune.com/product/meg ... ual-trans/
And is this the trigger wheel you're using? https://www.diyautotune.com/product/50- ... or-ka24de/
I wanna make sure you get it sorted out, and I can point our support guys this way if needed!
Jerry a.k.a. 'FoundSoul'
www.DIYAutoTune.com
www.DIYAutoTune.com
Forgot to updateFoundSoul wrote: ↑Thu Nov 03, 2022 10:29 amimportdude wrote: ↑Wed Jul 13, 2022 3:00 pm Everything is runing But cannot get it to run with the DIY trigger wheel megasquirt pnp2
issues were solved . It was the dreaded trigger angle issues
I landed on 319.0 with Distributor In middle slot for bolt and 15degrees
As a UPDATE.
July 2022 when cruising I somehow spun a bearing #4. This was going 60mph and barely any throttle
I disassembled the block and found #3/4 rod bearing heated and fused to the crank.
Not Sure what happened, but I'm thinking the machine shop did not check the bearings and or bent crank (shop was suppose to balance mic spec it all out)
I went and grab a spare Block and put in some spare new CP/arias pistons I had laying around. Added some more goodies. Also went with another machine shop that is more meticulous on the build.
Its Now
89.5 CP Arias sc7300 9.0.1 - 1st ring .019 2nd ring .021
Eagle rods
Race ACL STD main .002 and rod bearings .015
Tomei Cam gears at zero
Tomei pon-cams
Denso K24 Coils
BW S257sxe with T3 .82 housing
MSpnp2
results are
518whp 471wtq on E85
22psi
I think the cams are moving the Full spool alittle too much. I Will go in for cam tuning to try to move it sooner.
Engine wants to keep reving 7400 and the hp still not droping!!!!! Engine Has ZERO LIFT on 10mm studs with the washer. Engine just wants more power!
But since i'm on stock springs I will only rev out to 6800-7200
I ran out of injector for now(85%). I do not want to raise Fuel pressure past 55.
I'm happy at the power now, But If i find a good deal for 1700x I will shoot for maybe 600whp for **** and giggles
Its Now
Eagle rods
Tomei pon-cams
Denso K24 Coils
MSpnp2
results are
22psi
That seems like a fairly stout set up, I wish E85 was more readily available in my area.
Tough to find a good deal on a set of new ID injectors, as they're a map restricted brand.
