Tig filler rod for cast aluminum??
Anyone have experience on Tig welding cast aluminum tranmission cases? I would to reinforce the case on my Bluebird AWD turbo. I want to weld some thick aluminum plates to the outer case because these tranmissions are know to crack the housing when you launch them hard.
- LigouriRd.
So far I have only used 4043 and my welding professor used that same rod to fill some holes on a cast aluminum motorcycle fork. You will also have to preheat the aluminum before welding.
"There is no such thing as too much boost. You could have too little rod, piston, sleeve, head gasket or timing. But never too much boost."
'91 Nissan 240SX
'96 Nissan 240SX KA-T
'05 Grand Cherokee (4x2)
'85 Honda Nighthawk 450SC
'91 Nissan 240SX
pre heat is nessary with such a big piece and im sure you will be useing preaty thick metal.
KA24ET RB20 turbo, 460cc
