i think the scb actuator is bad (NOW WITH PICS)
so after installing s/c, then fixing all the leaks, then replacing a distributor(which went bad) the car is running good. except the vacuum being at 12in... before i put it on the scb actuator was hard to move. but now it stays full open at idle then when i close it by hand my vacuum goes up to 16-18in. with the car off it closes.. it feels too easy to move with the car running..
im tuned by nistune and every thing looks right. (fuel and timing map)
now for the test run. i floored it and i went straight to 0psi and the s/c is whining.
no boost at all
should i purchase a new actuator?
no boost at all
- Forum Moderator
Re: i think the scb actuator is bad
Yeah that vacuum is low...i create somewhere around 18-20 inHg vacuum at 800 rpm idle speed. Your vacuum shouldn't bee that low unless you had some sick cams in your setup. What source are connecting the hose on the bypass valve/actuator to? somewhere between the throttle body and the supercharger inlet? Find a copy of the Xterra FSM to see how the actuator should open/close at different vacuum levels.icnuthin wrote:so after installing s/c, then fixing all the leaks, then replacing a distributor(which went bad) the car is running good. except the vacuum being at 12in... before i put it on the scb actuator was hard to move. but now it stays full open at idle then when i close it by hand my vacuum goes up to 16-18in. with the car off it closes.. it feels too easy to move with the car running..
it's supposed to whineicnuthin wrote:now for the test run. i floored it and i went straight to 0psi and the s/c is whining.
j/k, even if the actuator/bypass valve was open all the time, you should still see some boost (2-4 psi depending on setup)
Let's see a picture of what the running setup looks like so far.
EDIT, I just noticed your other thread...please don't make new threads when the issue is the same as another thread...in the future, just update the old ones and people can give feedback in it.
yea sorry about the other post but im freaking out,
but i do notice that the valve does close when throttled.
it is so easy to move at idle. its also set to 900rpm
at first i had a hose out of the adapt. plate T to the fpr and the scb valve. and then i just took it off and left the valve open air and closed the vacuum line but i left the small one that goes to the s.c on...
im prob gonna take it off again and go over the plate to sc gasket but first another boost leak test for the 8th time.
What nipple on the actuator do you have the vac line hooked to? When i was messin with superchargers my supercharger didnt come with any of the vac lines and i mistakenly hooked the vacuum line to the wrong nipple and i would get boost at idle and none at throttle. My prob was i was using the the overboost part of the bypass actuator instead of the resirc part. Hope that was clear. Anyways, check the actuator and make sure your using the lower nipple instead of the upper and take your vacuum from the supercharger intake to the lower nipple on the actuator.
well when i got it there was one on it that was from the supercharger to the actuator..very short line, then i hooked up the vacuum to the other that was open then tried it without the vacuum but leaving the small line on. still nothing on both. i think the sc is bad.240cp wrote:What nipple on the actuator do you have the vac line hooked to? When i was messin with superchargers my supercharger didnt come with any of the vac lines and i mistakenly hooked the vacuum line to the wrong nipple and i would get boost at idle and none at throttle. My prob was i was using the the overboost part of the bypass actuator instead of the resirc part. Hope that was clear. Anyways, check the actuator and make sure your using the lower nipple instead of the upper and take your vacuum from the supercharger intake to the lower nipple on the actuator.
You should not be able to move the actuator when the car is idling. 18-20 in hg is alot. The way you have it hooked up, small line to supercharger is correct. Do not hook up the other nipple unless you have a boost solenoid set at 10 psi like nissan did it. If your still not seeing boost replace the actuator. I think i have one ill send if you pay shipping.
sure ill pay. ill do that before i buy a whole new s/c.240cp wrote:You should not be able to move the actuator when the car is idling. 18-20 in hg is alot. The way you have it hooked up, small line to supercharger is correct. Do not hook up the other nipple unless you have a boost solenoid set at 10 psi like nissan did it. If your still not seeing boost replace the actuator. I think i have one ill send if you pay shipping.
im gonna take pics up close so yall can see my progress. and i still have stuff to do like fuel lines wrapping.
im still trying to see what i wanna do for cooling. im leaning towards WMI. but also cryo2 bulb intake cooler and fuel cooler but i dont know how long co2 will last or how much it uses
Yeah, post up some pics. This whole things sounds very strange. I don't understand why your vacuum is so low, and why it would increase if you close the bypass valve...? It just doesn't make any sense. Are you sure you don't have any vacuum leaks? Did you connect the correct port on the supercharger to your brake booster vacuum line? And you're only running the short vacuum line on the bottom of the bypass actuator, correct? The other port is not hooked to anything?
correct, not hooked to anything.adamky wrote:Yeah, post up some pics. This whole things sounds very strange. I don't understand why your vacuum is so low, and why it would increase if you close the bypass valve...? It just doesn't make any sense. Are you sure you don't have any vacuum leaks? Did you connect the correct port on the supercharger to your brake booster vacuum line? And you're only running the short vacuum line on the bottom of the bypass actuator, correct? The other port is not hooked to anything?
ill get pics tonight my internet was down last night.
Does your brake booster vacuum line go to the port at the back of the supercharger, on the side closest to the block?
The T in the brake booster vacuum line... what is that for? Is that where you are getting the boost signal from, because that's what it looks like. If so, there's your problem, or at least, part of your problem. That line will never see boost. You need to T into the line going from the supercharger plate to the FPR. That line will see boost and vacuum, so this is where you need to get your boost signal from. The brake booster line shouldn't have any T's in it at all. It should go from the back of the supercharger, directly to the brake booster.
I can't see where everything goes, but that's what it looks like to me. Everything else, like your AAC/IACV setup looks fine.
the t is to my boost gauge. the one coming out of my sc is going to the fpr and i had it on the nipple of the scbv at first then i took it off and got same results.adamky wrote:The T in the brake booster vacuum line... what is that for? Is that where you are getting the boost signal from, because that's what it looks like. If so, there's your problem, or at least, part of your problem. That line will never see boost. You need to T into the line going from the supercharger plate to the FPR. That line will see boost and vacuum, so this is where you need to get your boost signal from. The brake booster line shouldn't have any T's in it at all. It should go from the back of the supercharger, directly to the brake booster.
I don't think you understand what I'm saying. You're not seeing boost right now because you have the boost gauge hooked up wrong. Neither the brake booster line, nor the small line going to the scbv actuator will ever see boost. The ONLY line that will see boost is the line that goes from the top of the supercharger adapter plate to the fuel pressure regulator. If you're not reading your boost signal from here, your gauge will never show boost.
You may have other issues going on. It's hard to tell from just pics and a description. But from those pics, I can tell you with 100% certainty that you have the boost gauge hooked up wrong.
- turbonola
ok, is that just for s/c setups because if thats the fact i told him to do it that way because thats where i have my boost gauge hooked up. if you are saying the brake booster never see's boost you are right. it never sees boost because of the checkvalve in line. other than that he should be seeing boost from what i'm seeing. do you mean that he shouldnt even use the port that he's using? i dont understand? help me understand s/c's more.adamky wrote:I don't think you understand what I'm saying. You're not seeing boost right now because you have the boost gauge hooked up wrong. Neither the brake booster line, nor the small line going to the scbv actuator will ever see boost. The ONLY line that will see boost is the line that goes from the top of the supercharger adapter plate to the fuel pressure regulator. If you're not reading your boost signal from here, your gauge will never show boost.
11.65@118 1.64 60ft
Yes, it is different for a turbo setup. In a turbo setup, your brake booster line will see boost because the entire intake manifold gets pressurized. I know many turbo folks use a vacuum block on the brake booster line and it works great for a boost gauge. But with a supercharger setup, the only part that sees boost is the upper intake runners, and the internal volume within the upper part of the supercharger itself (under the supercharger plate). All of the ports on the lower part of the supercharger, such as the one that goes to the scbv and brake booster, will never see boost because they are located on the intake side of the supercharger.
Right now, it looks like everything is connected correctly, except the T in the brake boost line needs to be removed, and the boost gauge signal needs to be T'd into the fpr line.
Sucks that the supercharger is bad. I figured there may have been other issues going on.
I sent you a text about the S/C unit. try and get me those numbers off it so i can get them to the guy i got the M62 from. I had none of these issues, all my issues were with the fuel pressure and injectors leaking. Also try send some pics of the rotors, I'd like to be able to show the guy the pics.
- Forum Moderator
hmm, it's hard to tell what's going on with your setup with all the million hoses running in and out...but from what I can tell, here are some suggestions:
Connect a hose directly from the supercharger actuator/bypass valve to the little bung/nipple on your intake pipe (between the throttle body and the supercharger inlet). This will keep the bypass valve open at idle and low load, but then as soon as you stab the throttle, it will close the butterfly and allow you to make max boost given with your setup. On my setup, this nets 18-19 inHg at idle and ~10 psi at wide open throttle.
Now if you are doing some initial tuning and want to keep the boost level low, connect a hose directly from the bypass valve/actuator to the 90 deg. nipple that's on the top of the supercharger plate (with it being tee'd with the fuel pressure reg. signal)...on my setup, this nets 18-19 inHg at idle and 3-4 psi in wide open throttle due to the butterfly being open all the time.
Resulting boost level/psi with this setup is all based on pulley size, belt configuration, if supercharger housing is ported, size of intake pipe, etc.
ok now im getting somewhere on knowledge thanks to you and adamky.klattr1 wrote:hmm, it's hard to tell what's going on with your setup with all the million hoses running in and out...but from what I can tell, here are some suggestions:
1. my boost gauge is hooked up wrong. i need to t off of the plate
2. where i had my vac line for the bv was coming from that plate so i was only seeing 3-4 psi and that would explain the im not feeling boost feeling.
makes so much sense. but the only thing im still having an issue is the idle not being at 18-19 inhg.
so im gonna try the other s/c i have
Re:
Happy SC days!icnuthin wrote:ok now im getting somewhere on knowledge thanks to you and adamky.klattr1 wrote:hmm, it's hard to tell what's going on with your setup with all the million hoses running in and out...but from what I can tell, here are some suggestions:
so I'm gonna try the other s/c i have
Well I hope you guys are still around. I don't know why everything I look up lately is 4 or 5 years old. What's with that? Anyway, if you have a min. I have a M62 4th gen 2001 Frontier supercharger factory installed. I put a vacuum pump to the lower actuator nipple and pumping to 10 it slowly leaks vacuum. If I open the the actuator by hand it leaks a lot. so is it bad? The upper one does not leak. on this one I can't tell when the valve is closed. Is that when the actuator is down or up? The small vacuum line (lower) runs to the SCB solenoid. The upper one is short and runs to the top back of the SC 5" or so. So I don't know if the top one closes the SCB or opens it?
If the leaking is bad then where can I get one?
