SC help
Re: SC help
I know this is a month old BUT for future reference:john e wrote:I need help with the vac. And Coolant lines. I'm not running a heater, egr, AAC or IACV. Does anyone have a diagram for the coolant lines and vac lines for this setup or something close
Assuming you are running stock upper runners, there should be no difference in coolant lines what so ever. You can delete the lines going to the throttle body, and the stock lower plenum just has a piece of a hardline for a heater hose that can be bypassed.
As for vacuum all you need is FPR and brake booster. Booster vacuum source is on the supercharger from the factory. The adapter plate should have threaded holes for barb fittings for the rest.
