O&J Performance KA24E Street/Strip Cams(New Price $175.0
- O&Jperformance
- KA-T.org Sponsor
O&J Performance is always looking for ways to improve performance in the KA24E engines.Thats why we know offer our own Street or Strip cams specs. for KA24E.
O&J Performance KA24E Cams
HYDRAULIC LIFTERS
Stage 1 one step above OEM Cams.
266 Duration
435 Lift.
Stage 2
270 Duration
445 Lift
MECHANICAL LIFTERS
Stage 1
280 Duration
475-480 Lift
Stage 2
284 Lift Dual pattern
485-485 Lift
Stage 3
286 Duration
490-495 Lift
Price $175.00 + shipping.
REMEMBER We need a core or a $75.00 core charge will apply.
Any other cams grind will have to be custom grind.Please contact us for your custom cams specs.
KA24DE CAMS AVAILABE.Please contact us for more info.
HYDRAULIC LIFTERS
266 Duration
435 Lift.
Stage 2
270 Duration
445 Lift
MECHANICAL LIFTERS
Stage 1
280 Duration
475-480 Lift
Stage 2
485-485 Lift
Stage 3
286 Duration
490-495 Lift
Last edited by O&Jperformance on Wed Sep 30, 2009 5:05 pm, edited 4 times in total.
http://www.ojperformance.com/ Tel-407-944-0064
Performance Parts,Turbocharger,Chassis and much more
Instagram O&J Performance
Facebook O&J Performance
Twitter O&J Performance
cam recomendation
Dear OJ,
Cam recomendation. Please.
1993 Hardbody 2600 lbs
Ford c4 Auto transbraked , yet to be determined hi stall , 4000 rpm on the brake now now
Nissan 9 1/4 " diff 3.7 Detroit locker
caltracs, M/T 26x 11x15, ECT>>>>>>>
Ka24e sohc forged rod,pistons
Head will has oversized valves and a clean up
standard 240sx intake with a custom plenum, 75 mm throttlebody
Stond alone ECU 1000cc injectors , big intercooler
tuned style exhaust manifold ECT>>>>>>>>
Probably a GT35 style turbo?????? AT psi ?????
The car is a strip orientated 1/4 mile street car and i want about 450 hp so i can comfortably go
10.99et ( sorry 11.01 i dont want no cage and harness ect.)
So what cam would you recomend?
standard cam has a " powerband 25000-5000 RPM
I dont want to RPM to the moon i just want whats nessecary to get the job done.
And do i really need a solid cam, hydraulic is maintenance free.
Mark from Australia
Mark from Australia
- O&Jperformance
- KA-T.org Sponsor
Re: cam recomendation
I need to know what is the compression on your engine.Before we go ahead and choose a cam.julienmark wrote:Dear OJ,
Mark from Australia![]()
- O&Jperformance
- KA-T.org Sponsor
If you want to keep the hydraulic lifters I will go with the stage 2.If you will like to go with mech lifters I will use the 290 Duration with 490 lift.
Last edited by O&Jperformance on Sun Jan 20, 2008 11:33 am, edited 1 time in total.
- O&Jperformance
- KA-T.org Sponsor
Any time.
same recomendations?
I have a ka24e pretty much the same setup with 8.8-9.0 compression t3o4e .48 ar
would you still reccomend the same cams?
- O&Jperformance
- KA-T.org Sponsor
Re: same recomendations?
Yes pretty much the same if you want to keep a good idle on a everyday car.If you dont mind some minimum rough idle you could use Stage with the mech lifters.drift9 wrote:I have a ka24e pretty much the same setup with 8.8-9.0 compression t3o4e .48 ar
- O&Jperformance
- KA-T.org Sponsor
Stage 2 mech lifters
- O&Jperformance
- KA-T.org Sponsor
If you run a stage 2 with hyd lifters no.But if you use a stage 2 with mech lifters I would recommend to use a springs but is not necessary.P_Productions wrote:Would I have to upgrade the valve springs in order to run a stage 2 cam?
- O&Jperformance
- KA-T.org Sponsor
pretty much what see on the stage 3 is the most you could use on stock pistons.
- O&Jperformance
- KA-T.org Sponsor
Here are all the cams specs if you are looking for something that is not available here let me know.We could have something special order for you.
Camshafts
Camshafts
dead link, but i went to the camshaft page
i saw crower and brian crower, but no o&j for the de
<b>Under Construction</b>
spun a rod bearing
be back in no time
spun a rod bearing
be back in no time
- O&Jperformance
- KA-T.org Sponsor
for the de I have many just let me know what your looking for whats your set up and we could take from there.Call me at 1-866-907-9745
- O&Jperformance
- KA-T.org Sponsor
Stock cam:
3500- 280wtq
4500- 265wtq
5500- 230wtq
6500- 200wtq
7000- 170wtq
3500- 190whp
4500- 240whp
5500- 270whp
6500- 250whp
7000- 225whp
O and J stage 2 mech cam
3500- 265wtq
4500- 320wtq
5500- 320wtq
6500- 275wtq
7000- 245wtq
3500- 170whp
4500- 240whp
5500- 325whp
6500- 335whp
7000- 325whp
Basic facts
-Added about 100whp at 7000rpms
-Added about 90wtq at 5500 rpms
Info by SleppyS-14
3500- 280wtq
4500- 265wtq
5500- 230wtq
6500- 200wtq
7000- 170wtq
3500- 190whp
4500- 240whp
5500- 270whp
6500- 250whp
7000- 225whp
3500- 265wtq
4500- 320wtq
5500- 320wtq
6500- 275wtq
7000- 245wtq
3500- 170whp
4500- 240whp
5500- 325whp
6500- 335whp
7000- 325whp
Basic facts
Info by SleppyS-14
- O&Jperformance
- KA-T.org Sponsor
ckeck your email
sorry if this is old and yes i still have a ka24e and is interested in getting these o&j cams but how much gain(hp/whp) would you get between oj stage 1 cam and oj stage 2 cams also which one would be recommend on a stock motor daily driver im looking to get some umph to it since i mostly travel highway/freeway thanks again
- O&Jperformance
- KA-T.org Sponsor
Thank You for your interest in our cams.Based on what I have I read in your post I would recommend a stage 1 hydraulic lifters.It will increase your horse power and your power band.khmer1 wrote:sorry if this is old and yes i still have a ka24e and is interested in getting these o&j cams but how much gain(hp/whp) would you get between oj stage 1 cam and oj stage 2 cams also which one would be recommend on a stock motor daily driver im looking to get some umph to it since i mostly travel highway/freeway thanks again
- O&Jperformance
- KA-T.org Sponsor
HYDRAULIC LIFTERSkhmer1 wrote:so whats the different between stage 1 and stage 2
266 Duration
435 Lift.
Stage 2
270 Duration
445 Lift
The difference is lift and duration as far as the cam goes.As far as drive ability you will get a little more top end with the stage 2.
ka24de cams
What do you charge for stage 2 cams for the twin cam ka24de?[/img]
