G'day everyone, I've started a turbo build on my Nissan navara d22 1998 ka24e and I've got a couple of questions.
So far I have:
t25 garret turbo
4psi or a 7psi internal waste gate
intercooled
2.5 inch exhaust
air/fuel ratio gauge and sensor
boost gauge and bov
t2 to t3 adapter
engine completely stock with around 250 000kms
I'm planning on running the 7 psi one with the stock injectors, would they be enough?
And as for tuning am I able to run nistune with the stock ecu or would I have to get a different one?
Is there any other ways to tune it that are easier?
Cheers
D22 navara turbo
- KA-T.org Sponsor
Re: D22 navara turbo
I would have to double check with my tech support guys (support@diyautotune.com) but there's a decent chance our MSPNP Gen2 (MSPNP-NS9501b) will drop right into that thing. If not, and MS3Pro definitely would do the trick, and nicely, with a ton of features you're not going to get with a factory ECU reflash.
https://www.diyautotune.com/product/meg ... ual-trans/
https://www.diyautotune.com/shop/mspro- ... s3pro-ecu/
Jerry a.k.a. 'FoundSoul'
www.DIYAutoTune.com
www.DIYAutoTune.com
