Am I wiring my LS2 coils up properly
http://www.diyautotune.com
drewssc400
Post by drewssc400 »
I am using the MS II V3 board. Car is a 97 KA24DE. Using 4 coils for a wasted spark setup. I'm using this picture for reference and I'm not sure where (C) on the coil plug should go....
(A) on all 4 coils grounded to the manifold.
(B) from coils 1&4 will go to pin 36 on the DB37 connector.
(B) from coils 2&3 will go to pin 6 on the DB37 connector.
(C) ??????
(D) +12V from the fuel pump relay or other switched +12V source.
Thanks!
drewssc400
I think I found my answer
(A) Goes to ground (intake manifold)
(B) Ground all 4 coils to pin 8 on DB37 connector
(C) Coils 1&4 to pin 36 on DB37 connector
(C) Coils 2&3 to pin 6 on DB37 connector
(D) +12V switched connection, probably from fuel pump relay
Thanks!
ViperGT
Re: Am I wiring my LS2 coils up properly
Post by ViperGT »
lol that was it did you put in capacitors for noise reduction? or just wire it up? sorry to bring up old posts but im running through all these similar posts about ign coils making sure everyones ready to boost
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
arp head, main, rod bolts
osk timing
custom downpipe
lol:
Post by supakat »
I just wired mine up. I have thought about this but never had an issue with noise.
ViperGT
Post by ViperGT »
sounds good
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
Matt Cramer
Post by Matt Cramer »
supakat wrote:I just wired mine up. I have thought about this but never had an issue with noise.
It's usually not a big deal. A bigger deal is that I recommend grounding the LS1 coils to the cylinder head, separately from the ECU.
Post by supakat »
Correct Matt. I have the stock harness for the coils and one is grounded to head and other to MS. I have my coils hooked up to a relay for 12v as well.
