Built silvia s15
S15Ka
Built silvia s15
Post by S15Ka »
Hey guys,
New to this forum, I'm sure there will be a lot of mixed emotions on my build. But a good opportunity came up and I purchased a built ka-t for a nissan silvia s15. I'd like to know what you guys think hp it's capably of making.
Build list
- 2.4L KA24DE-T
- Custom Polished Valve cover with large vents
- Race Port and Polished head
- KELFORD 272/272 camshafts
- JWT Jim Wolfe technology Adjustable cam gears
- CROWER Dual Valve Springs+ Retainers
- Head and block bored out and heli-coiled for 11mm head studs
- COMETIC MLS head gasket
- Head and block decked, micro polished, hot tanked and crosshoned
- ARIAS 8.8 Forged Pistons
- CROWER Billet Chromoly I-beam rods
- ARP L19 head studs
- ARP L19 rod bolts
- CLEVITE Rod and Main bearings
- COMPETITION CLUTCH Oversize Z33 stage 5, 6 puck
- COMPETITION CLUTCH Custom Oversized KA/VQ flywheel to mate 350Z face
- 300zx Z32 TWIN TURBO 5 speed transmission
- XCESSIVE VG to KA transmission adapter kit
- XCESSIVE VG shifter relocation adapter kit
- Nismo Short shifter with Solid bush
- XCESSIVE Aluminum 1 piece Driveshaft
- J30 VLSD differential
- SS braided clutch
- AEROMOTIVE 300lph in tank fuel pump (hard wired)
- BOSCH 044 in line fuel pump (hard wired)
-8AN VIBRANT stainless steel braided fuel feed with AN fittings(E85)
-6AN VIBRANT stainless steel braided fuel return with AN fittings(E85)
- AEROMOTIVE inline fuel filter 10 micron
- AEROMOTIVE adjustable fuel regulator 1:1 rising rate
- INJECTOR DYNAMICS ID1000 injectors
- AMS -8AN fuel rail
- AEM progressive 50/50 water methanol injection with 550cc nozzle jet
- PRECISION TURBO 6262 billet wheel, dual ball bearing, .82AR turbine with Vband outlet
- TIALSport MVS 38mm Vband Wastegate
- TIALSport 50mm blow off valve
- APEXi N1 dual SS exhaust
- SPEARCO intercooler
- Custom Stainless Steel Equal Length Top Mount T3 manifold
- Custom VIBRANT Stainless Steel T304 open dump pipe
- Custom VIBRANT Stainless Steel T304 3& down pipe with o2 bung
- Custom VIBRANT Aluminum Intercooler Piping
- Custom Hand Made Aluminum Intake manifold
- ACCUFAB 5.0L throttle body with TPS
- VIBRANT STAINLESS STEEL BRAIDED E85 braided fuel lines from tank to engine
- AEM Full Standalone EMS
- AEM IAT Sensor
- AEM 3.5bar MAP Sensor
- LS3 Individual Ignition Smart coils with custom coil bracket
- NISSAN HIGH OUTPUT Q45 alternator upgrade
-Tial super drift coilovers
-18" Work vsxx
-Wide body
