e85
e85
So what is going on with the e85 beta tunes? I am interested.
- KA-T.org Sponsor
- eazye2000
Awesome. Ordered my rail today. Just need to decide on 1200 or 1600cc injectors. Hopefully getting with you in the next few weeks. Unless you wanna piddle around with E85 on some 740cc's..R.S. Enthalpy wrote:I will test this on your car if you want... since you are local. I will do it at my cost... You just supply the fuel.
R.S. Enthalpy
- KA-T.org Sponsor
- chue240sx
are 740cc's too small for running e85? Just looking to make around 350-400 whp running a holset he341.
stock internals,t2 GT2871R, Unorthodox pulley set,FMIC, HKS SSQV 2, Apexi N1, z32 maf, nismo 740cc injectors,Prosport boost and oil guages, Innovate LC-1 WB02, enthalpy dual tune ecu for 91 and e85, Apexi N1 EvX suspension, cusco rear sway bar and front brace, megan tie bar, RUCAs, toe arms, traction arms, etc, works vsxx, Nismo solid red with white pearls, daily driving
seems a little big on the injector, are looking ot go about 500whp or more? when we do e85 setups, we usually go 20-25% larger than stock injector. 2200 is alot of injector, we also found that most cars with larger than 1000cc on e85 have a harder time starting ( over saturation on start up ) like i mentioned before, an evo x pushing 31psi on e85 only needs 1000cc, and it puts down 360whp let us know how it turns out though
- Kfred
31psi and 360whp on a modern 4 valve/clinder engine? That is really ****.,,71ka510 wrote:seems a little big on the injector, are looking ot go about 500whp or more? when we do e85 setups, we usually go 20-25% larger than stock injector. 2200 is alot of injector, we also found that most cars with larger than 1000cc on e85 have a harder time starting ( over saturation on start up ) like i mentioned before, an evo x pushing 31psi on e85 only needs 1000cc, and it puts down 360whp let us know how it turns out though
Eazye2000, keep us posted on the results.
RIP Nate(480sx)...
