can you tune my 97 d21 obd2 ecu? its obd2 like a newer 240 but has a single cam motor with a truck specific maf intake and cam. the intake uses side feed injectors.....
any possible setup or should i repin my harness for a s15 ecu and run the stock s15 maf / injectors etc.
remember it is a sohc so i pretty much have to stick with this intake. if i run the 89-90 intake it uses top feed injectors.
btw my setup will be
t3/to4e
7psi
550 or 740 cc injectors
stock truck maf blow thru or stock 240sx maf draw thru
let me know if this is possible
attention enthalpy, wondering if this is possible...
. 97 D21 . BELLTECH DROPPED . TORSION BARS .ENKEI'S . AZENIS . TURBO
NYR SCCA MEMBER
NYR SCCA MEMBER
