lower compression on stock ecu
Non-technical 240sx stuff in here.
500hpKA240sx
Post by 500hpKA240sx »
ok guys this seems like a stupid question but if I lowered compression from a 9.8:1 to a 8.8:1 would I have to have the ecu tuned? If you raise it you have to but for some reason I seem to remember seeing some people dropping compression on our ka's and driving around and breaking their engines in before they boosted them. I cant find anything on this question....getting frustrated
Re: lower compression on stock ecu
Post by airman »
Should be okay. You won't be able to fine tune the timing to make up for the lower compression, though obviously. Otherwise you'll be fine :) Don't know why I just now came across this post.
500hpKA240sx
awesome thanks man the compression ratio is 9.7 just found out and the closest pistons I could find were 9.1 so its pretty close and im having the head shaved so it should bump it up closer to 9.2:1. Ill post pics after the pistons come in and what not. doing a build for my gf's eclipse. and of course I over build everything lol. after this month I SHOULD be having the m90 on and running I need to have 2 pieces machined for the pulley set up and nobody will do it....
