tomei ka-t dyno..OMG
130-140mph @4000rpm wow..on YouTube. From what I'm seeing, that manifold is a bottom mount tucked under the factory heat shield. Am I correct?
- shift_down
Re: tomei ka-t dyno..OMG
- AFKOUKI
That car is N/A in this vid, not turbocham wrote:130-140mph @4000rpm wow..on YouTube. From what I'm seeing, that manifold is a bottom mount tucked under the factory heat shield. Am I correct?
87 PS.... and at 1:18 you can see the stock airbox and MAF on the stock intake tube.
Edit: its KPH not MPH as well, not trying to rain on your parade or anything
Your right. Good eyes. But thr video is labeled and says 9. There is after the pistons went in they finished and put the turbo on and dyno'd it. Check it out
It's a stock head w/ valve work and their own tune.
It's the haltech tune that's the big thing but they haven't revealed much...
Was just on another site. They have prototype pistons,valve and they also have new tomei cams in and testing with the turbo
